RCU Forums - View Single Post - some FS One questions
Old 02-04-2008 | 10:49 AM
CloudSkipper
Default RE: some FS One questions
Thanks I'll do that. Although I'm realistic about the ram/gpu limitations, I think it should be fine. If it works on 1.6 Ghz then 3+ Ghz should be good.
The no brainer here is to pick up a stick of non-dual channel 1 Gig ram for not that much in terms of price. My CPU's however are overclocked, so that complicates the issue of changing ram. I need to refamiliarize myself with my OC'ing settings which I tweaked so long ago that I don't remember anymore. Once I've sorted that, more ram will be the first thing, and then I'll consider over time how high I want to go with GPU.
EDIT: Before getting around to GPU though, I'll probably get an Alpha 40 trainer... priorities [8D]
Cheers
