RE: How much diff oil should be put in diff cup?
exactly what I was thinking! That is why it is silicone! If you fill close to the top you get the best differential action with the fluid as well.
If you guys are having leak problems you need to remember when you replace the gaskets to lube them up. You can use associated green slime or just use the differential fluid. This way they don't tear on the first run!
