RCU Forums - View Single Post - Need help with WM SS40 Steering Pushrod
Old 04-17-2003 | 02:40 PM
JimboP
Default Need help with WM SS40 Steering Pushrod
I can't come up with a good way to install the z-bend of the nose wheel steering pushrod in the steering arm. I don't see how I am going to make that z-bend go into the steering arm after the nose wheel assembly is installed in the motor mount. If I bend the wire then it won't move freely. If I install it before I put the assembly in the mount then it will get bent too. I am thinking about using a threaded rod instead with a clevis. Any help would be appreciated. As you know there are no text instructions with the WM SS40, only pictures.
JimboP
