ORIGINAL: GlennBurgdorf
Joe,
Thanks for letting me know your setup. It sounds pretty much like what I was looking at. Two questions though:
What weight is your model.
What voltage are you running.
Regards
Glenn
If memory serves me right, I am at no more than 3 or 4 ozs. under 11 lbs. Maybe more. I do not use the wheel pants, but I use larger wheels due to the field I fly at. When I first flew the plane, it was 10 lbs-13ozs with wheel pants. The plane is even lighter without the wheel pants and the wheels I originally was using. The larger wheels I am using now along with the NMP axles make the plane even lighter than the original weight. I am using the Comp C50 13XL, 20.5X14 APC, and Hacker Master Spin 99 Controller, APC Spinner, Jaccio regulator, JR switch harness, Hangar 9 turnbuckles on ailerons and elevator servos with MK hardware, JR 9 ch spektrum Rx with two satelite Rx's, Schulze 4mm connectors. All up wing panels are 15.8 and 15.6 ounces. I only remember the wing panel weights because I wrote it down on the root ribs.
I think the regulator I had in it was at 5.2Volts. I am going to change to a 5.7V regulator before spring comes around.
CORRECTION ON MY PREVIOUS POST - I MEANT JR 8411SA FOR RUDDER<G>
