RCU Forums - View Single Post - Servo reverser interference
Old 02-04-2008 | 10:40 PM
Piddler's Avatar
Piddler
Default Servo reverser interference
I have a dual elevator on my Carl Goldberg Sukhoi and have installed a y harness servo reverser on them. I did this, so I can have the ailerons set up on two different channels and only use one channel for the elevators. My radio is a an Hitec Optic 6. When I push the throttle up and down there is some vibrating interference in the elevators, it seems worse in the left elevator. Why would it do this? Does the servo reverser cause this? Maybe I should just go back to the y harness on the ailerons and 2 separate channels on the elevator.
Thanks in advance,
Brad
