Tiger 60 question
This is my first kit build and fourth plane, and I useally can figure things out. I just thought I would ask this question here, just in case. I am getting near the point of starting the covering. The instructions say to"install the fuel tank tray" after the plane is covered. The instructions have several items that are "installed". On those items, it does not say glue, epoxy, don't glue, or whatever. It just says "install". So far, I have either glued or epoxied everything except the fuel tank tray. Is there some reason that I shouldn't glue it permanent, before I cover the plane? It fits kind of snug and will be in a foam paded compartment area, but it seems wrong to me to leave it "loose". I can't see any reason for that, unless MAYBE you wanted/needed to put the battery underneath the tank. But even that seems like it would be a pain in the butt, and I can't imagine it needing nose weight.
Thanks for your help,
Pete
