RCU Forums - View Single Post - DIY Ignition System - Most simple
Old 02-05-2008 | 01:32 AM
  #48
bbuldoc
Default RE: DIY Ignition System - Most simple
ORIGINAL: hendrikm
Dear Bbuldoc,
Is the schematic at the beginning of the thread the final schematic diagram or has it changed. Is the PCB layout available?
The small coils you use, from what motorcycle did you obtain them?
Thanks for all the effort.
From South Africa
It is the final for simple one that without timing advance. We are trying to add some passive component to enable simple timing advance to this circuit. If you want timing advance I would recommend to wait for a day. Anyway I attached here the PCB layout and the photo of motorcycle that we use its coil. (Suzuki Akira)
ID:	870471   Click image for larger version
