RCU Forums - View Single Post - Trinity Reference 5000mAH battery pack
Old 02-05-2008 | 06:31 AM
wackywheelz's Avatar
wackywheelz
Default RE: Trinity Reference 5000mAH battery pack
If the sprocket moves a lot, pop the hub cap off and make sure the screw is done up tight. I use a spring washer to keep constant pressure, so it doesnt slip loose. Other possible solution (if the screw inside the sprocket is not loose) is shim 3rd gear of the gearbox, that tightens the output shaft eliminating any excess play.
