RCU Forums - View Single Post - 3W 100 Running Issues
Old 02-05-2008 | 09:27 AM
altavillan
Default RE: 3W 100 Running Issues
Yes you need a carb kit. For temporary running try removing the carbs gaskets/diaphrams and gently rub some raw synthetic oil into them to loosen them up. Check the filter screen for debri. Most likely the fuel pump diaphram is not pumping at a concistent rate causing the needle fluctuations.
