RCU Forums - View Single Post - Large Prop Balancing
Old 02-05-2008 | 08:48 PM
altavillan
Default RE: Large Prop Balancing
Before drilling for prop bolts measure to be certain the center hole is centered. Then balance it. Centering the hole almost always makes the latteral balance perfect. To balance the tips lightly sand the back of the light blade and then spray light coats of clear paint till balanced. The paint will evaporate some weight so re-test after it's dry.
