RCU Forums - View Single Post - Seagull Harmon Rocket foaming problems
Old 02-05-2008 | 09:54 PM
Delta3
Default RE: Seagull Harmon Rocket foaming problems
Couple of things, is the bung on thetank screwed in tightly enough and if you check your fuel lines maybe there is a small hole in one of them that is allowingair to get into the line, sometimes the fuel linesget minute holes in them. Maybe you just need to check the lines and the bung, replace all the lineswith new tubing and see what happens
