RE: Jetcat P80 issue with the Green LED
Hi Alain,
Sorry for the late reply, my real job has kept me very busy lately.
My guess is that you Tx antenna is up and too close to the ECU while you are starting. The electromagnetic field from your antenna is so strong that is is causing trouble in the ECU. Just leave one segment up while starting and you will be fine.
Regards,
