RCU Forums - View Single Post - Nylong Wing Bolts
Old 02-06-2008 | 01:08 AM
Aug's Avatar
Aug
Default RE: Nylong Wing Bolts
Thank you all for your help. The plane is a trainer originally designed for rubber bands. I just wanted to use a design on the wing that would be obscured by the rubber bands. I see the two dowel holes in your picture. I see the plywood strip you are talking about. I have one in the front and the rear. Can I use four nylon bolts, two in the front and two in the back or that would cause excessive damage should I have a bad landing?
This is the front of the fuselage wing saddle.
ID:	871283   Click image for larger version
