Covering Question
MinnFlyer,
I am also attempting my first covering job.
The scheme you posted above, do you cover the entire surface in white then place trim over that or are the areas of trim(blue and red) actually placed on the wood structure? I'm finishing a Venture 60 and the wing is mostly not sheeted so I'm not sure where the covering would then be attached.
Also, in covering the wing, should I run the iron over each rib after shrinking or will ironing at the periphery and subsequent heat gun and glove be enough?
