RE: Exceed-RC Raptor G2 Keeps Spining
You see it will always tip towards one side no matter how you adjust it. Basically you want to do the following:
disconnect the main motor. at low stick your swash should be balance and move to center stick and see if your swash changes and it should not be. do the same for high stick.
when you adjust the swash make sure all your trims are at center.
Andy
