ORIGINAL: Harry Lagman
Dar, that may be the case in theory but in many tests the guys at the field and I have run, these two props provide almost exactly the same load, typically within 100-150 rpm of each other at any given rpm point. They are to all intents and purposes the same static load and can be used pretty much interchangeably when determining performance.
Grant,
