Engine-out on a P-38:
I think another characteristic of a P-38 that contributes to it's problems when an engine quits is the airfoil at the wingtip.
I suspect the narrow wing chord and the taper can add to the problem. I would think that adding washout, along with differential aileron (applied sparingly at lower speeds), could help the engine-out situations, although it would cetainly not be a total fix.
Curious . . . if any of you have done this as a retrofit operation with your P-38's (or other warbird), did this affect your engine-out situations?
Regards,
Al Parry
[email protected]
