RE: HAVE YOU CONVERTED PIPED PATTERN PLANE TO SPEKTRUM/JR?????
in any case, the best result will be with the futaba fasst system, as the receiver only recognise the transmission of your transmiter and ignore everything that have not the good code, independantly of the frequency actually used.... unbeatable.... the same system is used to remote control satellites, missiles.. etc.... and the range is... no problem...
spectrum system is not locked by a code...
