RE: P40-E 60 size ARF problems.
Hello, i'm baaaack! I tried to start last night, where I would have to put the wing on the plane to start aligning the tailfeathers for epoxying in and discovered that the dihederal (sp?) we glued the main wings together at is WAAAAAY to much! When the wing sits in the saddle of the fuse, the TE pokes up off the surface of the fuse. I discovered that when I was epoxying the main wings together, I should have had that hardwood piece to verify the dihederal (sp?) that glues on the underside of the wing at the TE because it was at the correct dihederal. Since they are permanently joined together, I guess I will need to order a new set of wings!
DARNIT!! (I want to use stronger language here...)
Anyway, please advise on how I go about ordering a new set of wings.
Bryan
