RCU Forums - View Single Post - Using Micro servos, need help with linkages/pushrods
Old 02-07-2008 | 03:00 PM
vmsguy
Default Using Micro servos, need help with linkages/pushrods
OK... probably another naive question...
I'm trying to use a micro servo (Hitec HS-81) to move the lense on a camera. The problem I have is the holes in the servo arm and in the lever in the camera are too small to use standard size links.
I don't want to drill them out larger, there's precious little extra material around the hole, drilling it out, would weaken the material too much than I dare.
Are there "micro" size linkages???
I did a quick look on Tower and nothing jumped out at me...
A little help??
TIA
