RE: WildHare 28% Edge540T V2 Build and Mod
Looks great! You'll be flying in no time.
Have you done the servo install in the wings yet? if so, did you use H9 pushrods there as well? I'm using Spektrum, so no antenna to worry about, but your method is sound. If routed inside, try to secure the antenna to a corner of the fuselage opposite of where you have the elevator servo wires routed. Should be ok,,,just do a good range check as always!
Keith
