ORIGINAL: Snaer810
Well all I need to do is seal the engine box and firewall area, install an A123 batt system and install the RX antenna. BTW with all the servo leads and rudder cables in the fuse do you install the RX Ant. inside the fuse or outside? Folks say if installing the Ant. inside to try and keep it a good distance away from the servo leads and cables. Not sure which way to go.....would like to keep it inside.
On my last airplane I had a hard time getting a good range check. So I routed the antenna cable out the bottom of the fuselage. Had no problems after that and the antenna was still not visible without looking hard.
As stated above, if you run the antenna in the fuselage do a good range check. Many people run the antenna inside with no problems.
