RCU Forums - View Single Post - Angel S EVO Build Thread
Old 02-07-2008 | 09:15 PM
  #87
jfetter
Default RE: Angel S EVO Build Thread
ORIGINAL: elan120
Anyone can advise what is the spinner size? Starting to put together a list of parts needed for this plane, and I hope 5S is going to work.
TIA,
Kevin
Kevin,
It comes with a white spinner in the box, I was tempted to go CF but the supplied white one really completes the look. As for 5S, as long as you spec the motor out you should have no issues, I'd recommend you switch to the A50 12S over the A50 16S if you are going to go 5S, it is rated the same except for the 500 rpm/V instead of 380 rpm/V, the extra rpm's will offset the loss you'll have dropping from 6S to 5S...
Jack
