RE: Angel S EVO Build Thread
Jack,
I think the 15 inch by something prop should be the right starting point in my case, but the only thing I am not certain is the difference in P-factor between the 15 inch vs 17 inch like yours. Did you had to add more right thrust on your setup? One more question, could you comment on the incidence on the stab and the wing, I mean did you had to do any adjustment?
Kevin
