RCU Forums - View Single Post - Engine running Backwards?
Old 02-08-2008 | 01:35 PM
-pkh-'s Avatar
-pkh-
Default RE: Engine running Backwards?
Yes, sometimes it will fire up backwards. I've only had that happen to me a couple of times in a couple of hundred flights, but I always use an electric starter. Using a stick, you are probably going to see this happen more frequently than with a starter. I believe it is just bouncing back due to compression, and happens to fire up occasionally in the reverse direction.
