RCU Forums - View Single Post - Engine running Backwards?
Old 02-08-2008 | 02:47 PM
bkdavy's Avatar
bkdavy
Default RE: Engine running Backwards?
Another trick I use when the engine starts backwards is to pinch the fuel line. This will cut off the fuel supply and burn off the excess fuel. Listen carefully, and you'll hear the engine blip and then start running forward. Works about 90 percent of the time.
Brad
