RE: Accidentally Poked Hole in CompArf Wing
Buszz:
Sort of depends on the size of the hole? If you can get a small piece of 1/16 backing inside, would be best. Then use 5 min.epoxie or sim., fill the hole area, scrape off excess with playing card, and remove any excess with alchol and Q tip, cover with wax paper and let cure. Toutch up with kids crayon when well set. If you get a little dimple in the repair, simply add another light coat of epoxie and repeat process. You can add some ballons if needed, or wanted. ENJOY
