RCU Forums - View Single Post - Angel S EVO Build Thread
Old 02-08-2008 | 06:57 PM
  #94
jfetter
Default RE: Angel S EVO Build Thread
ORIGINAL: elan120
Jack,
The batteries are:
ThunderPower High Performance series
4450 mA
22C Continuous
40C Max
MaxAmps
4000 mA
20C Continuous
30C Sustained
50C Max
Motor:
Extreme Flight 4014T-570
Resistance (Ri) 17.5m Ohm
Continuous current: 45A
Maximum current: 80A (20sec)
Maximum efficiency: 85%
These are all the parameters I can find, hope is enough to run MotoCalc.
Kevin
Kevin,
The most important data out of everything is the internal resistance of the LiPo's, that really determines if you've got a dog versus a hot setup. I've looked up the other TP's and some other newer packs and made a guess based on that data and here are the results. Pretty good if you ask me, you're going to get almost the same performance I get with 6S packs (you'll be pushing more amps though) with only 5S, not bad! I'll be curious what you think once you fly it, from what I see, the numbers look great...
(Make sure you use the "expand to actual size" button to read the results)
Jack
