ORIGINAL: MMcConville
This is a complete no-brainer. The Spektrum receiver placement is not critical at all. Its only a little bit of an issue if there is a lot of CF in the model, but that also easy to get around by moving the remotes till the reception is best.
We've flow it it many different types of models in different configurations and it just works. Personally, I will never fly anything but Spektrum 2.4 again in anything.
I'm not going to get into any war on here and I not am going to say any more on this, but daggets the information you stated regarding Spektrum and how it works is simply very much INCORRECT.
The fuse is done with all but the throttle servo to be travel adjusted. I have one clevis to attach before I can adjust the throttle. Then the wing will be attached and I will rebind the whole system for neutral and gear down fail safe positions. Then I'm going to do the advanced range check procedure and check the data with the Data Logger. Will report when done with that.
