RCU Forums - View Single Post - Single cylinder balancing question.
Old 04-26-2003 | 07:57 PM
StarskiPZ
Default compromise indeed!
Even if you do balance the mass perfectly for the piston / crankpin / rod & crankshaft...
you will still have vibration - especially in the sideways plane from the rod / crankpin & counterbalance.
To get even near perfection, you need 4 cylinders to start, 6 is better.
But back to basics, if your engine is really bad for a typical glow, then you can bolt a small flywheel onto the crank.
It must be secure & marked so it cannot slip. Then drill a little hole (taking some mass away) when piston is at TDC in the flywheel at 180 degrees.
Is the vibration any different....? Its trial & error - but will give you an idea of weather the crank needs MORE mass balance - or LESS.
You can get vibration measurements using accelerometers and a 'Pico' device linked to your PC.
Depends again on how far you want to go...
have fun!
