RCU Forums - View Single Post - The VERY BEST Tip I ever got...
Old 02-09-2008 | 03:11 AM
  #37
Thunderbolt47's Avatar
Thunderbolt47
My Feedback: (8)
Default RE: The VERY BEST Tip I ever got...
[quote]ORIGINAL: cphoto
Here is another great tip...When you drill a hole through the Fuselage for mounting the switch, or whatever, and you want to put CA in the hole to harden the wood always put your finger over the hole to prevent CA from running onto the cover. Then instead of having CA on your cover you will end up with a big CA fingerprint on the side of the plane. This will help if you ever need to prove that it is your plane, plus you will probably have enough skin from your finger for a DNA sample as well..
That's The best one yet!!!
Here mine. "Don't ever argue over who was at the flight line first. When you win, you'll lose the plane and they get to laugh at you."
Had this happen once. Seen it happen twice.
