RCU Forums - View Single Post - Static Thrust of ZDZ 100cc B2NG Engine
Old 02-09-2008 | 08:02 AM
pe reivers
Default RE: Static Thrust of ZDZ 100cc B2NG Engine
Here's the rule for required static full pull out of a hover.
Will pull out at 1.5 times plane weight (no fun)
Will pull out with gusto at two times plane weight (too much fun)
Dick, could you check that rule using your engines/planes/experience and my spread sheet at your altitude?
http://www.mvvs.nl/prop-power-calculator.xls
TIA
