RE: B400 Grip and Spindle Question
I wish that I had a picture for you, but here goes a description. The order of items on the feathering shaft is :
small allen screw(add locktite to threads), small washer, silver bearing race with race facing into the hub, ball bearings with balls facing into hub, silver bearing race with race facing ball bearings(these three pieces are refered to as a single thrust bearing in the diagram), large thin washer, two bearings (doesn't matter which way they face), step washer with "step" facing the bearing, four thin spacers or shims (note: these do not appear in the diagram at all), rubber grommet. Repeat this order on the other side. Add a drop of Triflo to each bearing as you assemble them.
