RCU Forums - View Single Post - Mini Lst Stripping Center Diff (HELP!!!)
Old 02-09-2008 | 10:34 AM
bilsue2005(crash)
Default Mini Lst Stripping Center Diff (HELP!!!)
Hey Guys I have bought this super mini Lst and installed viccious diffs in the front and rear and LOSB1125 Ball Diff w/Outdrive BB: Mini-T,MLST/2 SKU: LOSB1125 in the center. I am running a Tekin 6.8 mini rage motor/esc combo and it's only at 1/2 power. With no reverse The batt. im using is a 1500mah 3 cell lipo 15C. I just got the new diffs in from la parts. I took them appart and greased them as recommended and put them back together and installesd them. Last night after I got everything back together I tested it out and it was doing great for about 2 min. and them the center wasn't turning. I took it appart (yet again) and the center gears were fine but the balls looked like they melted into the slipper (I dont know what gives) Is there a center that will live up to expectations? Also Sometimes when the old center gave a little I would tighten the screw up a little and then it would work great for a min. and then it would stripp out the viccious front and or rear. Pleas help!!!!!
ID:	873829   Click image for larger version
ID:	873830   Click image for larger version
ID:	873831   Click image for larger version
