RE: First Heli
The CP and CP+ would be a little easier to fly than the CP Pro. But the CP Pro has a 3 in 1 so you could hook up a gyro if you wanted to. I would recommend the CP+ to start out with then get the CP Pro bell hiller system when you are ready. If you are using the wooden blades get plenty of extras and get plenty of spindles and mainshafts. Those where the main things that I had to get when I was learning on the CP Pro. Usually the bigger the helicopter the easier it is to learn on. I could have easily bought a T-Rex with all of my broken parts on the CP Pro, but there are plenty of alternative helicopters that are good for alot cheaper. The E-Sky series has a lot of good CP helicopters that are reasonably priced.
