RCU Forums - View Single Post - wheels - Where to mount???
Old 02-09-2008 | 03:23 PM
Mike Connor's Avatar
Mike Connor
Default RE: wheels - Where to mount???
You should consider the most forward CG is probably forward of my line and you may want more prop clearance. Considering that it seems the leading edge of the wing should be somewhere between the front of the wheel and the axle.
Note - CG location is an estimate. Balance point is as supplied.
