RE: Installing Tailplanes- is there an easy way ?
I think that all the line methods have problems with stretch. What I use is a couple lengths of music wire (.032 - .039 - .047) jointed together with a small wheel collar. One end has a right angle bend on the end to drop into a hole drilled into the firewall or block added for the measurement. The other end I put a piece of masking tape which I mark so I can compare left side to right.
