RCU Forums - View Single Post - HAVE YOU CONVERTED PIPED PATTERN PLANE TO SPEKTRUM/JR?????
Old 02-10-2008 | 02:52 AM
alcarafa's Avatar
alcarafa
Default RE: HAVE YOU CONVERTED PIPED PATTERN PLANE TO SPEKTRUM/JR?????
ORIGINAL: daggets
in any case, the best result will be with the futaba fasst system, as the receiver only recognise the transmission of your transmiter and ignore everything that have not the good code, independantly of the frequency actually used.... unbeatable.... the same system is used to remote control satellites, missiles.. etc.... and the range is... no problem...
spectrum system is not locked by a code...
Mon dieu tu est vraiment idiot ou quoi ? il faut lire a concience pas ecrire sans savoir.
