ORIGINAL: ParkFlyer7235
So if I wanted to fly mainly indoors then the CX 2 is the answer. And outdoors the B400 or the CP (as far as which would be best for a beginner)? And how easy is it to break these things (other than the blades which I can easily replace)?
Exactly cx2 indoors others out, and its real easy to break these with a decent crash, normally its blades and bent shafts, id reccommend upgrading rotor heads and swashplates to metal and modify blades so that they fold in on impact which saves you lots of blades
In fact to save money in the long run on the cx2 for example then check out eat2muchrice links post and all the mods are worth doing to save money in long run, id say by far the cx2 is cheaper to repair compared to the other two
http://www.rcuniverse.com/forum/m_68...tm.htm#6821632
