RE: E-FLIGHT BLADE CP
I go through tail rotor motors like kleenex (~2-3 hours/motor). I am using a g90 gyro. Does anyone else go through at this rate? Interesting enough, I am starting to see that my 'glitching' problem starts up a flight or two before the motor goes bad. Finally I am seeing a correlation! Perhaps the brushes start arcing so bad and it is running at full current to maintain position that the noise overloads the filter caps and transfers to the 3-in-one? anyone else see the same effect?
Jordan
