RE: PassTime Perigee Build thread
A GREAT FIND!
Cleaning up a bit in the shop, I discovered an entire roll of Silkspun Coverite, which they don't make anymore. After resin, I started to use this as a primary covering. Iron-on, no sanding, no smell, very strong, fills with primer really well. If I had known about this, I would have done the fuselage in it. Oh, well, at least I can cover my control surfaces.
After application, I would go straight to primer. Then sand, putty as necessary, sand, shoot a second primer coat, lightly sand, then paint.
