ORIGINAL: toesupwa
ORIGINAL: CCW_tester
What should I use to bond wood to fiberglass?
There are special epoxy's formulated for bonding to fiberglass. If your LHS doesnt stock it, try the local DIY store
Never thought about that before.
I have always just brushed the first coat onto the wood, and then pressed the fiberglass into the resin.
For polyester resin, there is a "Bond" coat, which cures tacky and flexible.
If you use finishing resin all the way through, the fiberglass can end up a bit brittle.
