RE: Sundowner 50 Arf
I just checked mine and it has the same thrust angle built in. It does not look like a mistake. All of the laser cut parts are glued tight with no gaps or mis-matches.
The 55 AX has the same bolt pattern for mounting as the 46 AX. Everything should bolt up with factory hardware. I will find out soon. The engine should be here next week.
