RCU Forums - View Single Post - When to "Draw a Line"?
Old 02-10-2008 | 11:18 PM
DRC1
My Feedback: (10)
Default RE: When to "Draw a Line"?
ORIGINAL: chipper11077
Thanks for the reply,
I certainly understand between the maneuvers drawing a line... I guess what I am asking about is like in a half reversed cuban 8 or a reversed sharks tooth on the 45 uplines ... I assume its draw a 45, half roll, and draw the 45 again before pulling.... but I THOUGHT I had been told of an example where it would be draw a line, roll and then go right into a pull without drawing a line again.
Thanks again!
Scott
I believe you are referring to an Immelman and a Split-S...
Immelman - Pull 1/2 loop then immediate 1/2 roll on exit
Split-S - Perform 1/2 roll then immediate pull 1/2 loop and exit
There are many roll variation and more about the downgrade associated for not rolling / exiting properly...
Larry Diamond
