moving on to jets
Seems to be a lot of interest in a GWS A-10 Wart Hog. Has twin ducted fans on it. Foam construction. Since you have flying experience the transision should be fairly easy. Just remember you need to keep speed up to maintain control. No prop wash over the control surfaces. Dead stick landings could be a little hairy unless you have a rapid decent (or it will result in rapid decent) and takeoffs will lack good directional control until you build up a little speed. You might do a search in the forum for the GWS model and see if you can learn a little more about it or look for some reviews on ezone for the plane.
