RCU Forums - View Single Post - Nitro Models Pitts-40 Special Design
Old 02-11-2008 | 08:47 PM
  #38
linkadrip's Avatar
linkadrip
Default RE: Nitro Models Pitts-40 Special Design
Yes you will get the confirmation as opjose says. great picture i will be buying more then one tail gear since i have several planes that need a better tail gear. I looked up the Installation of the tail gear in the manual that the gear goes to Cap 260 i think and it gives a pretty good explination. but you picture shows it much bettter. thank you very much appriciate that alot.
I dont see any reason why the engine cant be mnounted to the side or at a 45 if you prefer even straight up. if one want to cut the hole inthe top of the cowl. Just take some inginuity. I thought about mounting at a 90 degree but decided i wanted to make things difficult as usuall for myself soi mounted the engine inverted.
So now i'm waiting on a 90 degree Fitting for the exahust from Horizon. then i should be able to complete it. Probably will fly it withthe tail gear that came with it maybe. But i'm going to order the new gear As soon as possable just casue this tail gear sucks. wouldnt be so bad if it was't So flimsy.
I'm sure the plane will fly Great just have to rember its not a TwisT.
