RCU Forums - View Single Post - New Pro-Link Offerings
Old 02-11-2008 | 10:10 PM
lov2flyrc's Avatar
lov2flyrc
My Feedback: (24)
Default New Pro-Link Offerings
Hi Guys...
Just a quick update on the latest offerings of our Pro-Link line of landing gear.
Boomerang Elan:
The Elan Gear will be in-house this week. Our new Pro-Link Elan trailing link gear offer zero strut offset and have 1/2" trunion lock style upper strut connection. These will be offered as struts only or as a combo with our new Pro-Link retracts. Combo packages include the following:
* Pro-Link Elan Trailing Link Main Struts
* Pro-Link Main Spare Springs
* Pro-Link Trailing Link Nose Strut
* Pro-Link Series Machined Retract Set
* 2 Robart Air Tanks
* 2 Air Fill Valves
* Intairco 2 5/8" Main Wheels and Brakes
* Intairco 2 1/4" Nose Wheel
* 4 Packs Heavy Duty Airline Tubing
* Brake Line Tubing
* 4 Airline Tee Fittings
* 2 Air Gauges
* Adjustable Rate Retract Valve
* Ultra Precision UP-6 Brake Valve
Custom combo's (should you not need specific item or prefer another brand item) available upon request, just call for pricing.
Our Elan Pro-Link retracts are identical in size to the Robart 630 series retracts but offer machined T6 aluminum frames and trunions along with a rail flange sized specifically for the Elan. These are Drop-In fit with no modification required to the retract flanges or airframe (still need to remove a little material beneath the retract for cylinder clearance).
Elan Combo Pricing: 849.99
Elan, Boomerang Intro and Boomerang XL packages are available through Dreamworks Model Products and Boomerang Jets USA.
NEW Heavy Weight Large Struts - You asked for it, we Deliver!!
While our standard large Pro-Link main struts have become the "Must Have" solution for most sport jets, many have been looking for a set to handle a bit more weight. We have delivered.... While our standard large mains are most suitable for aircraft up to 30lbs, some have had issues with the springs retaining tension when flying 25-30lb planes off rough terrain.
We went back to the drawing board and redesigned our large mains to offer a Heavy Weight model for those larger aircraft and rough terrain pilots. Our new Pro-Link Heavy Weight mains offer an additional 8lbs spring tension (at the wheel) per strut, providing trailing link dampening for up to 40lb aircraft. If you tend to land a bit hard or fly off fairly rough terrain, our Heavy Weights large mains are for you!
KingCat:
Our Pro-Link KingCat struts are in testing phase now, we expect to have sets available just in time for Florida Jets. Pro-Link KingCat struts will be available through Dreamworks Model Products and BVM Jets shortly.
Bandit - BobCat:
Our Pro-Link Bandit / Bobcat struts have become a very popular item! These are a Drop-In replacement for the BVM Duro Strut and almost eliminate flex plate breakage completely, not to mention greatly improved ground handling. Available NOW from Dreamworks Model Products and BVM Jets.
Flash and Lightning:
These two airframes are next in line for production, we expect to have sets available by mid April.
Details and pricing should be posted on our (and our dealer) websites shortly. Feel free to call with any questions you may have!
Todd Witkoff
