RE: Top Flite B-25 ARF (Tecnical, tips, suggestions)
Ditto the fuellers - never had a problem and make life much simpler.
BUT......just blew several hours trying to nut out a good way to mount them. The nacelle cover and cowl are both out as I want to remove these when required without disconnecting fuellers (and running in without cowls so they're definitely out). Finally mounted on an aluminium bracket using the existing cowl tab bolts, and access from the rear through louvres - no more holes in cowl.
Oh wait, that's one done.....[&o]
Cam
