RCU Forums - View Single Post - Everything Radial Engines
Old 02-12-2008 | 04:41 AM
  #1205
Flugmax
Default RE: Everything Radial Engines
Hello to all,
ITS a KMP Super-Sea-Fury,
http://www.kmp.ca/product_info.php?c...e7ed9e95b27f0e
which is much larger than the thunder-Tiger, the wings are much deeper; landing speed with that weigt is relativly smooth and slow, you see it in the video beyond
http://www.youtube.com/watch?v=oVmEW...eature=related
Weight is about 7,8 Kg, with fuel 8,5
flight under normal konditions is ok and neutral, in the video there is heavy wind from the front left side, so it seems the plane tends to roll right side, but thats wind;
that radial i also had in the focke wulf, 2m wingspan, 9,5 Kgs;
http://www.youtube.com/watch?v=6tKns...eature=related
into FW 190 i place now the famous MOKI VT50-4 (50 cc 4stroke gas engine- the cylinder is from the 250cc radial ) ) www.airworld.de
than i had to make service, cause the ball-bearings were rusted, so i had to dismount the whole engine to change the bearings,
and i putted in nirosta-bearings;
fotos of *intim* Saito beyond, is already running again
Greeting from SALZBURG; AUSTRIA
ID:	876543   Click image for larger version
ID:	876544   Click image for larger version
ID:	876545   Click image for larger version
ID:	876546   Click image for larger version
ID:	876547   Click image for larger version
ID:	876548   Click image for larger version
ID:	876549   Click image for larger version
