RCU Forums - View Single Post - Maiden Flight How To?
Old 04-19-2003 | 02:37 PM
BingoFlyer's Avatar
BingoFlyer
Default Maiden Flight How To?
One thing not mentioned in any of the above is if you are flying off from a hard surface hold enough up elevator in to keep tail wheel in firm contact with the ground, when near flying speed let off the up until the plane is on two wheels when flying speed is reached rotate,
The reason for the up elevator during the roll out is to make the rudder less sensitive (without the elevator you could be all over the place).
